I have a 2001 cummins 2500 all stock. Just recently put fuel gauge on and at idle I am reading 13psi and driving down highway I am at 10-11psi. I have a new lift pump on order but wont have for a few more days. Is it ok to keep running truck with this fuel psi till I get new pump in this Thursday. Or should I leave it parked for the few days.
  • Replies 6
  • Views 1.2k
That is within Bosch's parameters for a stock truck. I cant see it hurting anything unless something is bout ready to go. No good way to determine that however. I have driven mine on less before I knew anything about the importance of good fuel pressure.
Yep.,  as long as you have positive pressure I would say it is ok to drive if you need to.  I wouldn't make a habit of it, but life happens and we can't just pause everything because of something like this.
there are a TON of stock 24v trucks drivng around wiht no FP gauge and no fuel pressure at all haha.
good deal, thanks for the help, I am sure I will be asking for more help later down the road.
ok thanks, yes it is summer compared to most up of yall up north. Its 80 degrees this week in the dfw area.
