- Replies 7
- Views 6.3k
KATOOM 2 posts
SilverMoose 2 posts
Hawkez 1 post
Jolsen 1 post
Popular Days
I think anything is a benefit, especially replacing the restrictive banjo bolts. But the main feed line coming from the tank is still a big restriction. Running the big line kit from the filter to t
I have looked at similar kits. And I will be ordering one in the future. I currently have a GDP fuel boss pump. I will be replacing the line between the fuel filter and the vp44 and the line going fro
I still have my factory lines from the filter to the vp and they are maybe 1/4" but the banjo's are horribly small. The bolts cant be much over 1/8" of an opening. Very restrictive. I need to add
I am running a airtex lift pump and have my pressure gauge hooked up at banjo bolt coming off the injector pump. I was looking and Vulcan they sell a big line kit with a tee that I can mount the pressure solenoid. Just doing a 1/2 inch line from the fuel filter housing to the injector pump- would that be beneficial at all since the rest of my lines are all still factory. What are yalls opinion on this.
Edited by 2001cummins
add
