Fuel Pressure Gauge needed on 12 Valves too
- Replies 13
- Views 7.5k
Mopar1973Man 3 posts
jlbayes 3 posts
JAG1 2 posts
Cowboy 2 posts
I never liked the diaphragm pumps design a whole lot, I've had multiples fail (non-Cummins). One the linkage broke, fell apart, and because it was mounted to the injector pump, the whole governor hou
You still need a needle valve inline... Works as a shutoff in case of a leak, and more importantly, a snubber to dampen injection pump pulses. Bosch specs are 3-10 PSI. Stock diaphragm pum
Yes that is what they were doing.
In trying to find why my old 1992 truck idles terrible after an injector and VE pump change (runs good otherwise), I've been checking for air leaks/ fuel leaks/ timing etc., I decided to replace the lift pump and delete the fuel heater since they looked like they were weeping fuel.
I found when I took off the old lift pump the linkage that pulls down the diaphragm was no longer connected to the actuating arm that rides on the cam. This means I drove around for about a week with a new VE injection pump and no fuel pressure
. This was odd since most mechanical pumps fail from a worn leaking diaphragm, not a cheaply pressed in linkage inside. In looking at the original L/P from 1992, it was built much better and had twice the miles on it and still worked. So off I went looking at new L/Pumps,but all were from Korea or Turkey and all had the same cheaply built insides as the one that failed. I went to Cummins parts an found they even sell this new cheaply built version as well but theirs did not say where it is made
This is the moment I learned even the old 12 valves need to have a fuel pressure gauge as well.
I'm installing it with no Isolator, but, will have two lines going to the gauge so if leak develops the outer line will capture the leak and let it drain in the engine area. Not sure about all the ways yet but figuring it out.
Suggestions very welcome, thanks.
