Erratic Fuel Pressure
- Replies 14
- Views 6.5k
notlimah 5 posts
tbo1450 3 posts
woodtrucker 3 posts
dripley 1 post
Popular Days
They're pretty quick to blame other things other then it possibly being the pump. It's a real shame how they do that and had I known that prior to buying I would've gone a different route, because the
You might want to run that by FASS. It seems to me that most folks have a drop in pressure when that pring gives them trouble. Are you running a mechanical pressure gauge or an electric. The brain on
Does the DDRP have a return ball and spring? If so then I feel you'll just be wasting your time calling FASS. All they'll do is send you a new ball and spring and the same problem will com
I may have posted here before. I have had this issue for sometime and have read that is a concern and also read that it's not a problem unless fp drops.
My fuel pressure mostly runs at around 18ps and down to 14 psi at WOT when towing a heavy load.
I noticed yesterday that while unloaded, I drove to round trip 5 hours and let truck sit for about 4 hours. Then when I got in it to leave to go home from work, my fuel pressure was bouncing up a lot. It will run at 18 psi or and it just so happen when cruising in 5th gear, the fp would drift up and down from about 24-25psi back down to 18psi. It did this a bunch of times and slowly settled out the longer truck ran but never completely cleared up. didn't do it at all on the trip.
very strange. It's a ddrp-02 pump. thoughts?
Sounds like it might be a return spring issue. Can this be replaced easily or should eat it and upgrade lift pumps?
This lift pump probably has 40k on it.
