- Replies 81
- Views 27k
AH64ID 19 posts
Mopar1973Man 18 posts
jlbayes 9 posts
trreed 9 posts
Yep, sounds like a HX35/40 hybrid with a 8 blade compressor. Me thinks Mopar1973Man has caught the the power bug...
So fun fact of the day, there are two different versions of the HX35. The 8 blade HX35's were 56 mm. Then, Cummins quietly switched to a 7 blade version that's actually a 54 mm inducer. I found thi
Mike was talking about checking his stock turbah, that's where my comment originally meant to apply.
I got a turbo from @CSM and I went ahead and got it pulled down to rebuild it. While its apart I figure I would measure out the turbine and compressor wheels. Here is what I got.
Compressor
Inducer 60mm
Exducer 83mm
Turbine
Exducer 60mm
Inducer 69mm
From what I found online this is a HX40 compressor wheel. The HX35W is 56mm compressor wheel. So this should be a rather nice boost (pun intended). Waiting for my bearing kit to come.
