- Replies 18
- Views 3.7k
01cummins4ever 7 posts
Mopar1973Man 4 posts
IBMobile 4 posts
SilverMoose 1 post
Out on the road with no tools it's hard to do diagnostics let alone repairs but if you can get a test light or volt meter..... With the head lights turned on use the 12v test light or volt meter
There should be power to terminal 30 of the high beam relay only when low beams are on. When high beam is selected power is sent to terminal 86 and the coil is energized then the power will flow from
Once you get high beams working check out post from January 18. There is a write up and pictures to repin the plugs. Makes the lights better.
So I'm out on a road trip and last night when I turned my lights on the brights never came on, the bright is illuminated on the dash but no headlights,
I have just recently upgraded to the dual sport headlight from DAP, and before I left I also installed the relay wire harness kit from DAP, and they were all working fine for the last week or so. I still got the dim side but no brights. I checked fuses and relays and are still good, I am wondering if it's in the mfs switch on column or light switch on dash, Any ideas what to check, I'm out on a road trip so kind of limited to what I can do.
