Failed alternator and failed tuner
I got a job that a 2001 Dodge was having lock up issues typically. Now the owner had the BD noise filter, the APPS wiring mod and ground mods. Still in all the truck ran with a surge and dropping of power. The old alternator I measured at 0.1 to nearly 0.2 volts AC. He replaced the alternator I measured today and its right about 0.04 to 0.05 marginal. Still the loss of power and surging. The owner has a Bank's tuner on so I opted to removing the MAP leads and return to stock and the Wire Tap. Went for a test drive and the problem is gone. Moral of this post is alternator noise can do damage to even 3rd party device like tuners.
  • Replies 3
  • Views 2k
What alternator brand would you recommend getting? I feel like the off-the-shelf rebuilt ones from Orileys probably aren't worth a great deal in quality.
Honeslty just one with a good warranty,  Test it when you install it and go from there.
If you have a good alternator shop local go talk with them.
