- Replies 4
- Views 1.2k
Mopar1973Man 1 post
dripley 1 post
JAG1 1 post
015point9 1 post
Popular Days
X2 on what Mike says. The basket should springs to keep the bottom of the basket on the bottom of the tank. The corrugations in the straw allow it to flex and follow the basket down. This
Typically there is a spring that holds the lower half of the basket down in the tank bottom. I would consider going to a drawstraw or something else if the basket is damaged. You only going to fight t
Stainless screws are what you want to use if you need them. On my old 92 first gen I replaced the main body of my fuel basket using a 4 inch ABS straight coupling and stainless hardware. Part of the f
Scored a fuel tank yesterday, and in process of correcting 1/4 tank issues. Is it alright to use stainless metal bolts and a nylox nut to keep basket in position. My corrugated draw straw is the thing only providing tension between bottom of basket and top. I’m extending draw straw, so no longer will draw straw provide spring tension. I'm thinking the basket needs something to keep draw straw sucking near bottom of tank. I don’t know if stainless steel or nylox is OK to use in fuel system... or should I use some type of glue?
What is OK to use in fuel system?
Thanks
Edited by 015point9
