- Replies 18
- Views 8k
Thatguy 8 posts
Dynamic 4 posts
Mopar1973Man 3 posts
notlimah 2 posts
Sorry, I've been busy... Not a lot of time to get on here. Yes, I was going to comment that .070" is too tight for the direct clutch. It will come on before the band releases fully, causin
The man you need to talk to is @Dynamic he is our site transmission guy.
Yea either keep trying Dave or you can call Jon and see what he thinks.
OK so I recently rebuilt my 47re and have just over 1000 miles on it now . right around the 800 mile mark I started getting a pretty noticeable 2-3 bind up and I've been chasing my tail trying to catch it ever since.when I rebuilt the transmission I originally put in a superior front servo, the one with the sleeve and 2 o rings that restricts the release oil flow. I thought that was my problem so I swapped it out for a new billet double ring, double spring servo with billet cover. That didn't cure it either. I'm all ears at this point, everybody I've talked to says go with the TCS servo and there 4.2 lever and it'll go away. But I'm not ready to drop the trans to change the lever out unless I'm 100% sure that'll fix it. Trans specs are as follows
Goerend triple disc 17LC
Georend vb and there 3.8 lever
Band set at 72in pounds and 2 turns out(I've tried it anywhere from 1.5-2.5 turns and 2 turns seems to feel the best
Line pressure set at 175psi with the TV lever tied at 80%
Rear forward 4 gpz set at. 025
Direct 5 gpz set at. 070
Firepunk anteater tcm
