2nd 3rd 47 RE tranny Problem
- Replies 6
- Views 1.6k
Mopar1973Man 2 posts
jeremyf9806 2 posts
dripley 1 post
kzimmer 1 post
Hi, my name is jeremy
Excuse me to disturb you,
I have a dodge ram 24V 2500 99 with a 47 RE tranny,
I have a little problem with my tranny>
All the shifts are good, but the problem is the 2nd to 3rd hesitate, i need to accelerate more to pass this shift, and the 4 is ok >
Ive changed the governor pressure only, not the transducer,and there is no changing! but I ask to myself if the problems would be a 2-3 valve stuck on the valve body, or the TPS is faulty! I adjust the front band and the rear too, the fluid was correct, red, and there is no particulate on the filter he was clean!
So I need to your help before changing something else for nothing!
I have no DRB scan tool, and not pressure gauge!
Thank you for your help in advance>
