How to import / Export custom tunes in the IQuad App
Android
Some devices don't allow the link of the quad app to the .json file type of the tune.  You can still import manually.
1. Open the quad app
2. go into your custom tune menu
4. next a file explorer will open.  Each phone is a bit different, but you want to click the settings in the upper right, then "show internal storage"
5. You will now see this structure.
6.  you can navigate to the downloads folder and click the tune you want.
IOS
Also, regarding loading a tune on iOS. The easiest way that we have been able to do it is to mail the tune to ourselves. When we opened it on iPhone 4 mail app and then open the attachment we see this:
Click on the highlighted icon to open up the sharing button. It will load up options of programs to share to. Like this:
When you see that, simply choose the Open in iQuad option and you should be good to go.
Update for the iPhone implements a twirly when loading tunes or saving parameters. It will also give the option to reset to defaults if loading tune parameters fail. (i.e. when trying to load a V2 tune to a Legacy tuned Adrenaline it will fail a lot).
Edited by Me78569
  • Replies 125
  • Views 69.4k
    I've got to upload my Edge Comp look a like tune. I'm pleased with the performance and MPG is nearly the same as my old Edge Comp.
  • https://mopar1973man.com/files/category/22-quadzilla-standard-tunes/
  • I dont know.  I validated both tunes and they are the same.  They both load for me as well.  Confused.
  • 4 months later...
Some reason when I download the tunes and send them to my iquad ios they do not come up at all. Can someone tell me what's going on?
  • 9 months later...
I’m having issues downloading tunes on my iPhone it’s in my files but it’s not showing iQuad at all. Any help would be appreciated I’m new to this
Did you follow the directions on page 1?
All I can speak for is Android. But when I download a tune it lands in my download folder. Then I got to the iQuad app and then press the Import Button. Then go to my Download folder and select the file I wish to import. Apple products should be something similar.
  • 5 months later...
On the iPhone there is no import button that’s the problem. I’ve tried everything and can’t get it to work
have you tried this?
@Quadzilla Marco any news good or bad about loading tunes on Idevices at this point?
@Otto8335 you downloaded the file and emailed to yourself correct?   then tried to open from attachment into the iquad app
@Me78569 yes that’s correct. And when I try to open the file and select what app to use it with IQuad doesn’t show up
@Me78569@Me78569 yes that’s correct. And when I try to open the file and select what app to use it with IQuad doesn’t show up
