- Replies 6
- Views 1.7k
Mopar1973Man 3 posts
JAG1 1 post
Dieselfuture 1 post
015point9 1 post
Thought I would put in needle valve in fuel pressure line, I'm using elec gauge. In the directions, Auto meter (gauge maker) says in couple different places says to use snubber. I like the idea of needle valve, if nothing else valve can used as shut off valve to that line. Still going to put in snubber (just to be safe) . 100 DF air dog. Branching off fuel line about where motor meets trans.
Question...........
The Needle valve, where is best position? All the way open or slightly open? Or just play with it a bit to find best position?
Your thoughts please.
Edited by 015point9
