- Replies 27
- Views 12.5k
Mopar1973Man 8 posts
dave110 6 posts
Dieselfuture 5 posts
Killer223 4 posts
With t6 and a good filter you can very easily run the oil out to at least 10,000 miles. I've done oil analysis out to 20,000 on t6 (filter change at 10k) and the oil was still in great shape. If you w
Best way is to contact Blackstone labs, and ask for a sample kit. Cost is currently $38 to analyze for extended changes. They will send you a report, and how long you may go. I did this and when
ideally you want to keep the oil changes at or around 500 hours. that's the spec for most modern oils. yes some can and do go longer. but 500 is the formula cummins recommended for the new trucks. 15K
Now I know this has been covered a lot, but no one could ever really answer the question I have. Figured I'd ask here since we have our own oil expert on board. I know the change interval in the manual says 7500mi. My situation in a bit different being my truck only sees ~ 5000 mi. a year. It is a work truck and I usually only use it to pull trailers and haul. It does not see a lot of highway driving either. I use Rotella 15-w40 and change twice a year or every 2500 mi. Can I change only 1 time a year and be safe? Should I go to synthetic if I only change once a year? Our mech at work is old school and still believes in the 3 month 3000 mi. thing. Some of the vans there may only have a few hundred miles on but still get changed every 3 month. I believe that is over kill as oil has improved a lot over the years but I don't know. Is 1 year too long? 6 months too long? What would you do?
