- Replies 11
- Views 5.4k
dripley 4 posts
Rhagfo 3 posts
Mopar1973Man 2 posts
CTcummins24V 1 post
Well thinking my VP44 died during injector install.
Background;
Truck 2001 Dodge 2500 5.9 with 302K miles, DS Power puck, and FASS DDRP-02 that delivers 17.5 psi at idle and 15 psi at WOT.
I replaced my tappet cover gasket about two months ago and needed to remove the VP44 at the time, looked at the data plate, and thought I took a picture of it, but didn't. It looked to be the original VP44, didn't notice and rebuild information. Restart went as expected bleed the system, cranked several time fired and ran fine.
Then about a couple weeks ago, I decided to install a set of Bosch RV275 injectors. Install went as expected, torqued hold down bolts to 89 in #s, and injector tubes to 27 ft. #s. Restart was more difficult than before. Once started lots of white smoke and rough running. *&(%&(*$*^%#%!
So I replaced the stock injectors, thinking bad new injector, same results. Truck is not where I am currently at so, called it a day. about a week later, I put back the RV275's being extra careful, and same white smoke.
One thing I noticed this time was prior to attempting restart, I pressurized the fuel system ahead of the VP44 by bumping the starter. This is with injector lines 1,3,& 4 loose, at that point I had fuel at those ports, I didn't think the 17.5 psi that my FASS lift pump provided would push fuel through the VP44 to the injectors.
Thanks for input
