- Replies 12
 - Views 7k
								dripley 4 posts
								Greenlee 3 posts
								Mopar1973Man 2 posts
								Dieselfuture 1 post
I have a couple thoughts on this. One, the new connector tube might be slightly different from the old and not sealing to the injector. That is letting fuel by the seal and the pressure is pushing by
This is the only thing I will disagree with. The injector to connector tube seal would only leak into the return rail. The leakage on the manifold would only be the high pressure line to connector tub
Sometimes it takes few days for fuel to stop coming out from behind the nut. In my opinion it's extra fuel behind the nut that comes out when engine is hot, aventualy it stops leaking, no need to kill
I searched the past 45 pages of articles looking before asking. 1999 Dodge Cummins 2500 with fuel leak at #5 cylinder at injection connector tube and injection line nut. The tube had a cracked O-ring so it was replaced with a new tube. On start up no leak, 1 mile down the road no leak, up on the interstate for 6 miles and it's leaking again. Retightened but still leaking. Pulled the line off to check the mating surfaces with also looked good. Still leaking, any ideas?
Part 2: This is for me to understand. The tubes pops out easy, no problem getting the removal tool on the tubes. Once in place how does it stay in place and not turn when tightening? First time I changed my VP44 I had to double wrench the 3/4" or 19mm nuts to break them. Way past the recommended 26 or so ft/lbs. Does the slight taper fitting in the injector help keep the tube from turning? Just curious. Thank you for your time.
