- Replies 21
- Views 5.9k
Mopar1973Man 8 posts
CumminsTech 4 posts
dripley 3 posts
01cummins4ever 3 posts
Could have blown a hose or pressure relieve valve on compressor. Had this happen on another vehicle. If so something maybe causing it to overcharge. Only way I know how to check is with a set of mani
If you have the gauges you could rig up something on the freon fill line and hook your air compressor to it. I was going to do that to mine but my circumstances changed and I no longer needed to.
, I would pull a vacuum test on it first just to see if it will hold a vacuum. If not a couple cans of cheap freon should show a leak. If you don't have the tools they usually can be rented at an au
Started up my truck a few weeks back and I heard a loud pop and hiss...I thought it was just an issue with fuel as the truck was sitting for awhile. Get back in it a week later and run AC and it's not blowing cold at all so I blew something up. Hopefully just a hose. Any way to pressurize the lines with air to leak check?
