- Replies 33
- Views 6.1k
oldsilver 14 posts
Mopar1973Man 8 posts
dripley 5 posts
Dieselfuture 3 posts
If the boost elbow failed and let full pressure to the waste gate it would open a lot sooner. That would be your leak going down the tail pipe. Thats why @Mopar1973Man suggested pinching the air line
Trust me turbo mounted exhaust brake will not affect your towing ability. That is 10,000 pound of hay. I've towed much heavier loads and never had EGT issue even with 3" exhaust.
Is your boost elbow adjustable? is it possible that the adjustment screw moved?
Hi everyone I am new to this forum. I have a 99 dodge 3500 that I have owned since new. I am recently having higher egts, lower fuel mileage and lower boost. My truck has an edge comp box that I run on 3, pusher intake, pac brake, HX35/40 Hybrid turbo from PDR, RV275 injectors, stock lift pump mounted on the frame with 3/8" fuel line and no banjo bolts. 12psi at idle, about 9 at wot. AFE cold air intake and 4" exhaust. So recently I put a new IAT sensor in because my fuel mileage dropped to 9-10 coming back from South Dakota with 10000 pounds where I used to get 15. It raised it to 12 but my boost is still low at about 21-22 psi and my egts go to 1200 real easy. I use this truck to tow my camper and side by sides all over the country and next year I am going to CO and theres no way I can use it in elevation with those egts. I have tried to check for boost leaks and haven't found any. I am aware that I need to get rid of that turbo and exhaust break so I can get a true 4" down pipe but I have had this set up for years and have not had these problems. Looking for help because everybody I call just wants to sell me stuff. I am wanting to do some upgrades this winter for power and reliability, cause reliability is most important to me but I need to fix this problem first. Oh ya I took my elbow off my turbo and with the truck not running the exhaust break is wide open. Sorry for being so long winded I just can't figure this out. Once this is figured out I would like to do some up grades.
Also just put a crank sensor in about a month ago cause I got a code and I replaced my vp44 at 100000 miles and I have 144000. It was just a rebuilt bosch from Diesel injection service in St.louis
