Return lines into fuel module questions
- Replies 4
- Views 2k
dripley 1 post
Dieselfuture 1 post
notlimah 1 post
015point9 1 post
Popular Days
I'm not sure how Airdog runs their lines. What's the instructions say? You will still use one of the small return lines from the metal piping coming from the overflow of the VP and overflo
...Top of fuel module return lines…the smaller connection (roughly) is 5/16, the larger connection is 3/8. With Airdog 100 where would you connect the larger line?
Return from engine or return from Airdog pump?
...Being larger lines are usually better in most cases (fuel line, exhaust, etc)
Would there be any benefit going to larger return lines to fuel module?
Thanks
