Communication issues (& more)
To start I have a 99, 2500, Auto, 2x4, 211,000, Lift pump in tank with Relay, 275 HP Bosch Injectors.
I am the second owner & got the truck in 2001, IIRC it has 15,000 on it.
To make a long story short, I just finished doing a bunch of things I have been putting off for too long now.
Recently replaced (in order of installation):
Vacuum pump (http://www.fixinrams.com/)
PS Pump (https://www.genosgarage.com/) & Hoses (https://ormebrothers.com/).
Brand new Bosch 275 HP Injectors (Had Edge Jammer Stage 1's & wanted to see the difference)
ECM from https://carcomputerexchange.com/    (Lift pump was not turning on reliably & WTS light was acting all wonky)
Fuel Filter housing for 00-02 Cummins https://www.genosgarage.com/product/dodge-ram-cummins-replacement-fuel-filter-cannister-gg-fc98599/360  I was trying to troubleshoot the lift pump driver issue in ECM & Manged to crack the 99 Housing, so $180 later here I am....
VP44 from https://www.bluechipdiesel.com/ (This is the second VP44 I have put onto the truck, the first very early in life, due to dead Lift pump)
So here is the deal.  As I mentioned Ive owned this truck pretty much its entire life & have put just about every mile on it.  I had the vacuum pump, PS pump & injectors put into it by a local Dodge shop, because I did not have the time to take care of it.  no issues/worries with that.
off & on for the last year or so I was having issues with the ECM turning the lift pump on.  I dug into it a bit & called the folks @ Blue Chip & Doug suggested that I just run the lift pump off of the Wiper circuit (as its hot during "run", but not "start").  while that worked fine (the truck would start & run every time), once of the side effects was that I was getting a P0230 code.  I called Blue Chip  back & he said that is because I did not have a load on the ECM (because the lift pump was disconnected) & that I should just "stick a fan on it to blow across the Inj pump" so that the ECM would see the load.  I didn't like that idea, so I wired another relay on that output (the exact same relay that I am using for the lift pump) & much to my surprise that did not resolve the issue.
I did a bit of research & called 6 or 7 ECM sources & found that car computer exchange seemed to be knowledgeable about the Cummins specific issues & had a good answer to each of my questions (Im a Manufacturing Engineer for a company that produces devices that measure air pollution).  They were waiting on cores & said if I return mine I would get it quicker than if I waited to order one & then send my core back later.  So I did that.
I replaced the ECM & fuel filter housing @ one time & rewired the Lift pump back to the ECM where it should be.  every few years I check all of my grounds to make sure that there is no corrosion (like we get any weather in San Diego, right...............) & that everything looks ok.  I purged all of the air out & fired up the truck & it fired up after a little cranking.  HOWEVER......... the CEL came back on again. I hooked up the scan tool, cleared it & fired it back up again.  no more CEL.  Yes I did something stupid............. I did not read the code(s) I just cleared it/them.
I replaced the Injection pump & when I went to fire it up, I found the batteries were on their way out (slow cranking & no fire).  they were 5 years old so I replaced them.  Hit the key with the new batteries & it cranked over great & fired right up.  HOWEVER the CEL is back on again.
I broke out the $10 China Freight scanner & it came back with "there are no codes" (yes the CEL is on)  This is not the first time this has happened.  So I broke out the OTC Genisys, & the freaken thing wont talk with the stupid truck.  This is not the first time this has happened over the last 8 or 9 years.  Ive had this issue off & on for a while.  Ive not cared because the truck has worked fine & not had any CEL's so why would I care (paying for that now..............).
Here is where it gets weird.  If I use the HF scanner & force it to clear the CEL it will do it.  if I ask the OTC to clear the CEL, it will not.  neither of which will "get data from the truck".   the CEL comes back on just about every time I try to start the truck.  Ive cleared & started it 20 or 25 times since I replaced the Inj pump & most of the time the CEL comes back on.  I have tried a few things. like checking connections & Grounds & other such things to figure it out, clear the CEL & fired it up & it comes back on........
MORE....................
So........ the questions.......
I have a factory manual & have dug into the schematics & see that there appear to be 2 Comm buses.  once is the CCD & the other is the SCI.
I have read a bunch of stuff on this site as well other places, but am kind of confused about how this works & what does what.
as much as anything Im trying to learn with these questions, not to just fix my problem, so bear with me.
I get that the CCD talks between the ECM, Timer, Dash, PCM, etc to transfer information from one place to the next.  it is also present on the ALDL so I would assume that a "scanner" can talk on the buss as well to get data out.
It appears that the ECM & PCM are connected to the ALDL on pins 6, 7 & 14.  Its interesting to me that there is a single transmit line shared between both computers, but they each have separate receive lines.
SO............... When I hook up my scan tool cheap *** scan tool what is it talking with?  the ECM?  through the SCI lines or the CCD
 When Im using my OTC & turning on & off the AC Clutch, Trans Solenoids, lift pump, etc.  what buss is it using?
When there is a code that the trans is not working correctly, where is that coming from?  is the scan tool talking with the ECM via the SCI & its getting the codes from the PCM through the CCD?  How the heck does this work.........
Shoot........... I didn't want everything in one HUGE post............
So, Specifically to this problem.
How do I go about troubleshooting my communication issue?  I took the OTC & plugged it into my wifes Mercury & it allows me to see everything & do everything, its working correctly.
I have had issues with the Truck talking to scanners before, but Ive also had it work just fine & allow me to turn on the trans stuff & to datalog ECM & PCM stuff & watch the APPS voltage go up & down & everything you would think it should be able to do. so I know that it has worked before.
IMO, I need to get the scanner working before I can figure out why the CEL is on.  I suppose I could assume that its the same P0230 code, but I dont want to assume anything...........
thanks folks.
Bob
Edited by Bobalos
  • Replies 51
  • Views 17.8k
  • 3 buses   SCI CCD J1939   SCI: is used for troubleshooting and talking from the obd plug to the ecm and pcm.  This is nothing more than a obd compliance bus in my mind.
  • JTEC refers to the controller, PCM.
  • however I think the likely issue is just a shotty rebuild of the ecm.  AC noise shouldn't fry the ecm that fast.     I would replace the alternator if you are seeing a ton of ac noise for go
BTW, I wanted to say thanks to everyone for all of the help & assistance.  This was a very frustrating deal & it was compounded by multiple issues.
So....... THANKS!!!
Now onto the heater core, Dash & all the fun that is going to come with that.  I need to search & see if there is a "how to install a heater core in 30 minutes or less" instructional.  LOL.
Bob
Here you go...
thank you sir!!
can you replace the dash top w/o having to remove it can see that you can get to the Pass side screws, in the video, but can you get to the drivers side as well?
Bob
Yes you can get to all the screws. I've replaced a few dashes now and used @Mopar1973Man 's article as a guide. I didn't need to pull the HVAC box so I just rolled the dash back toward the seat.
The drivers was a little tough to get to but can be be done.
thanks guys.
I know its pretty far off topic, but did you buy the OEM Dodge dash (& where did you get it from)?
Has anyone tried the Geno's garage Dash?
thanks again
Bob
Got mine from LMC Trucks. Matched up quite well. About $300 to the door. $25 of that was for washwers for screws on top of the dash.
I second the LMC dashes
