- Replies 22
- Views 5.3k
jlbayes 6 posts
Mopar1973Man 4 posts
GSP7 4 posts
NorthernDodge 3 posts
Ep27 is the flasher you need for the 98+ trucks.
I got the led's(yellow front turn & clears for rear) and flasher from amazon. The lights are pretty bright but wanted them that way. They draw 4.4 watts. Flasher works just fine. h
Ebays
I am going to be ordeing new headlights soon and would aslo like to change the rest of my exterior lighting to LED's (excpet fogs). I just started researching the LED's and have a few questions I hope someone can answer. It appears you need to add a load resistor for the lights that blink. I aslo noticed that flasher relays are now made specifically for LED's. My question is is either one of the options viable for the blinkers, do you need both or just one or the other. Do the lights that are constant on need to have a load resistor added as well. Would the LED flasher relay work for towing?
Thanks
d
