Hey guys sorry to bring this up again! I have searched and haven’t found answers to my questions! So I would like to upgrade my stock headlights. I have ruled out hids because of price and all. I think I would like to do the sport light upgrade. I need someone to post a link to lights they have bought and love!! I’m looking for smoked stockbstyle headlights but don’t have to have them. Now my question is if I do this swap is it completely plug and play? If inget a Geno,s Britebox is this goin to work well with this setup? Thanks guys!!
I found a sport wiring harness and britebox together at Genos has anyone used this ? Is it good quality? If I get that all I will need is housings and bulbs correct?
  • Replies 55
  • Views 15k
  • HID's in a halogen housing with no projector is a no no, HID's in a HID projector = win.
  • I built my own as I wanted a simple set with no frills. They are extremely easy to do as well as setup. On cf you were likely told no pnp lights, if they said no hids period shame on them. Also on the
    4.3k bulbs will be a warmer orange color light. 5k bulbs will be more of a bluish colored light. Very minor differences.    Here is 5k bulbs... My driving lights are like a 3k bulb...
Yeah by the way you guys are a bad influence on me spending money, but I can't wait to be able to see.... early Christmas is what I told my wife. Now I'm anxious to work on my truck again.
@Me78569 once I figure out my cracked head situation and she can move under her own power I will do so:thumb1:
Sorry dieselfuture I have been out hunting and just checked the sight! I’m not even quite sure myself what to get I haven’t made the move yet... let me know how you like yours!!
Will do, may be a few weeks.
@Dieselfuture any of the one piece housings should work for you. I would look for one that has adjustment so you can fine tune them.
So I got all the parts except the bullet shroud does not fit inside housing, too big around and I had to order apollo2 flat that Mike has with his d2s. My question is for high/low my harness came with brown/white wire that is not in the plug 9006 that it came with, I got to put that in and before I do it backwards any one has a picture maby, thanks.
Edit. I think I'm asking about wrong wires, as I'm looking at instructions on line it says it doesn't matter how you plug them in its only powering silinoid for hi/low. I haven't got to the plug that originally plugs into old bulb yet. Still learning....
Edit. So hi/low to get it right, need to switch white and brown in morimoto harness.
Edited by Dieselfuture
Look closely you'll notice they just took the shroud and sanded it on a belt sander.
@Mopar1973Man here is what they look like, are you saying you can see where they sanded flat part even more to where there is a hole? If so I guess I can just make my bullet shrouds work, just was under impression apollo2 flat stile fits right in :ahhh:apollo_2.0_projector_retrofit_shrouds_2_1_1.jpg.f71587283790e37181f63fd9dde6ef22.jpg
Edit. Now that you said hat I think I can see a hole right through the shroud, aaaaaahhh, I think I'm going nuts.... next time will be listening to my wife and just by a complete set, NOT.... lol.
2 minutes ago, Marcus2000monster said:
Darn I wish I had the money for this upgrade! Get some pics please! @Dieselfuture
I just put a few in Mike's thread, you probably already seen them though lol.
So, ..... I love mine, if you're patient you can try doing d2s if not get h1. Both will be better than anything else out there.
One thing I thought I had figured out is couple of pins that need to be switched around for high/low to work properly, whell that part works but when I turn fogs on by pulling out switch it will turn my high beam on :doh: and even by switching hi/low it will keep highs on until I push in the switch for fog lights in. @Mopar1973Man guessing need to move pins around some more? If you ever close to your plug can you take a picture of it?
On 12/2/2017 at 9:40 AM, Mopar1973Man said:
I stand corrected... Thank you for the find...
I had to cut off about a1/4" on top side to make em fit in, just to clarify for anyone else looking at apollo 2 flat shrouds. And my original bullet shrouds I was going to use were too tall and would of hit the lenses or been right up next to them.
Good to know @Dieselfuture
Sounds like you got one of the pins. I had to try a couple combos to make mine work correctly.
