Cranks strong, won't start
- Replies 18
- Views 3.8k
FWBDieselJay 8 posts
Mopar1973Man 4 posts
JAG1 2 posts
notlimah 2 posts
2001 Ram 2500, 5 speed, 4x4, 183k, 5.9 Cummins
i was going about 50mph after driving about an hour, I got a dead pedal intermittently for about 10 seconds, then the truck died. It cranks strong, but will not start. No signs of any combustion whatsoever. Will fire off with a spray or two of ether but dies as soon as ether is burnt up.
Codes: P0122, P1693, and heater grid code (can't remember the code number)
Filter bowl full of fuel. Fuel filter changed about 3 weeks ago. 15 psi out of the lift pump. Swapped fuel relay. Swapped cam position sensor. Opened line out of ignition pump and have fuel when cranked. Opened line at #1 injector and have fuel there when cranked (did see some bubbling). Disconnected LP wiring, and cranked, still have fuel out of ignition pump, which makes me think the injection pump is good.
Im out of ideas. Little help?
