rear axle spacer blocks
- Replies 12
- Views 3.8k
Nekkedbob 5 posts
dripley 3 posts
Killer223 1 post
Royal Squire 1 post
I did not have that problem with either one of mine. Slapped a hitch on and never looked back. This is the current one.
personally I would look into raising your trailer axles to level it out, I dont know if they have been flipped yet or not but its a common procedure for people wanting more ground clearance on the tra
Well I finally bit the bullet and bought a 5th wheel. As most of you know our 4x4 trucks sit a little high and the rear of my bed is a little closer then I like. I did some research and found that dodge made at one time shorter spacer blocks that was 1 7/8 inches shorter then stock. I checked today and the local dealer said that they are not available and none are listed in stock in there system. Soooo I had a thought that I should be able to just have a set machined off and shorter u bolts installed.. The RV dealer that installed my hitch said that they send there rigs with this problem to a local welder (I have dealt with him and he does excellent work) to weld dropped attachment points on the trailer to raise the ride height of the trailer. I don't like the last idea and would like to hear what the rest of you have done when you had this problem. Just for reference the trailer is a 1987 21 foot Aries by Aljo and is not much higher then a bumper pull trailer.
