Typical lock/unlock issues PLUS
- Replies 6
- Views 2.2k
skyhigh4by 2 posts
Mopar1973Man 1 post
Dieselfuture 1 post
CTcummins24V 1 post
Just picked up a 98 24v that is having the typical TC lock/unlock issues BUT also sometimes the TC is not unlocking at all and when coming to a stop it stalls the engine out. Put it in park or neutral it fires back up and then you have to play the throttle to get it rolling or it will just stall out again also just driving around I can tell the TC is randomly locked because the engine will really struggle to pick up speed (sometimes I can tell TC is unlocked and everything feels fine). I haven't done any testing yet but from what I can see there are several wires wrapped with tinfoil
, I know it has a new alternator, new lift pump, new interstate batteries(connections look very clean) and it has been to a trans shop a couple times but not sure what has been to the trans itself if anything.
Mostly I am wondering if the TC staying locked when coming to a stop + being locked when it shouldn't be is related to the typical locking/unlocking/hunting issues or if Im trying to chase down 2 totally separate problems. I will start with the alternator testing and tracking down as many ground points as I can.
