Talked with @Quadzilla Power today about the 2.7 beta -> final move.  We both decided that the boost offset feature was causing more trouble than it was worth.   we have reverted how the late model trucks read  boost to using the 13 psi offset.    The way the truck drives is perfectly fine if idle psi is 0, 1, or 2 psi.   It is annoying but trying to solve the issue just complicates things more than most are willing to work with.
the mpg trip and mpg meter +  improved handoff stayed in place.
I know I have said this a few times, but I think V2 tuning is wrapped up and done done.    Now onto V3 :whistle:
:shifty:
kidding of course.
Edited by Me78569
  • Replies 44
  • Views 9.9k
  • Quadzilla Power
    Quadzilla Power
    If you built tunes on the 2.5 profile (the standard V2 Dodge 1998-2002 v2.5) profile then they should still be there when you update the vehicle profile to version 2.7. If you are moving from the Quad
  • Quadzilla Power
    Quadzilla Power
    Unfortunately there isn't a real good way to fix that other than removing the data. If you have access to your tunes now you can export them all to yourself, delete the app, redownload (or just clear
  • Did someone say V3?? We're waiting patiently Nick...
Nick sorry what vehicle profile do we use with this flash to have the mpg stuff, and is there a new app for it also. I don't see mpg stuff in version v2 dodge 1998-2002 version 2.5 or just use the v2 quadzilla only test2 version 2.7 I guess it's says that :think:
Edited by Dieselfuture
mpg is still in beta so that is the v2 quadzilla only profile.
Either profile will work, but the public profile doesnt have the mpg stuff yet.
OK I remember now you saying that, now that boost offset is defaulted by new tune what should I set it at.
boost offset is no longer.  just ignore the setting.
It's saying set it between 10 and 50
I guess no matter where I set it its just going to ignore it by default anyway with new flash?
the new flash does not have the code enabled in it.
Sorry I'm not that bright, that means it just won't respond to what I set it to in the 2.7 quadzilla only app, it will just ignore it since it's not enabled, so even if I set it to 50 it will change nothing as its not part of new code. I think that's what you're saying. Don't let me keep talking, already feel stupid.:shifty:
I'm not messing with you, just want to be sure, :poke:
I'll take it as yes :kick:
Edit. Just reread it few times and yeah I'm not that bright you already answered my question twice but I'm not a code writer ether, it takes me a little bit. All good now moving on. Awaiting v3 :mad@computer:
lol setting boost offset will do nothing.
Not sure if it's related but today I drove the truck with new flash and when I got off the hwy sitting at stop light I noticed some smoke went by the truck so I reved it up few times and it smoked mostly white with light blueish tint to it every time I hit the pedal, but when I took off it was normal grayish smoke. It was idling around 11 for timing, not sure if it's related to timing. Drove around town for another half of the hour and it never did again
Edit
Fuel pressure was around 17-18 psi unless vp timing piston is sticking
I know that it can be a pain to hit menu button on top left corner of screen so wanted to share this. I got this s6 that has an older software on it and when I downloaded the app 1.9.40 from download section my phone also has a larger circle with 3 buttons on it in bottom left that is much easier to touch. Now I don't know if its my phone that does this or something else, but on my other s6 that is up to date with same app I only have the smaller menu button top left that is hard to excess. 20180122_172623.jpg.e738fa2fa18c0ab101891261fed6cd8e.jpg
  • 4 weeks later...
Is it still the case now or something changed. It looks like 2.7 got some more updates not sure what else changed.
I think quadzilla released the json update for the app.
I just updated to @Me78569 long idle flash, and tried 98-02 profile, loading bar is there but I didn't see mpg stuff, went back to Quadzilla only test2 and both are there. I didn't see an update for the app, does app on phone needs updated too?
you should just need to update the profile.  I have tested this on my phone the and far right 3 sensors are Eco, Gallon trip, and build date
