- Replies 27
- Views 5.9k
Kodiak24V 9 posts
Mopar1973Man 8 posts
Me78569 5 posts
notlimah 3 posts
you are running a lot of fuel for the hx35, that's why you have high EGTS. I would drop wiretap down from 1600 to 1200
I figured it out. lol when I disconnected then reconnected the negative battery cables to install the injectors, the quad went back to level zero and I didn't notice... I did include 2 data logs from
I’m sure if he babies it he’ll be fine for a while, just really hard to baby it when you got the go fast parts on!
Just installed DAP 7x10 sac injectors yesterday in the 2001 24v. I set the quad to 150 fueling by 18psi but am only hitting 3k to 3200 max fueling. Is this normal? Should I be maxing fuel? I don't feel any power difference after installing the injectors up from stock. I'm hitting 30-34 psi on the HX35 just like before. Not really anymore smoke then stock. I started the fuel @ 95 @ 0 psi and ramped it up to 150 by 18psi and figured it would hit 4095 but it doesn't.
