So I finally got around to installing the 103lb springs and pushrods which went well started truck with no problems and runs well. But after sitting over night had to turn over quite a bit to get it to fire off. I think I must have a leak somewhere between vp and injectors but I can't see one. I used all new o-rings from DAP and new copper washers I was a little hesitant about the washers though b/c new ones were 1.5mm and old were 2 mm but guys at DAP said it should be fine. Any ideas where to start?
So yesterday when I got home before turning truck off I cracked a few of the injector lines loose to bleed off any possible air or re-seat them and truck cranked normal all day today so fingers crosse
