Black Smoke - Normal? If not where to start looking?
- Replies 35
- Views 6.1k
leety 12 posts
Mopar1973Man 5 posts
Me78569 5 posts
dripley 4 posts
The problem with leaving the horn in place is that the system only charges to xx psi that way. I think 15 pounds. You can do it that way sure to get obvious leaks squared away.
If you are still on stock intercooler boots my guess is boost leak. This is the tester the shop I go to uses. You test from charger to right before Intake horn. You can increase pressur
Soapy water in a spray bottle works for just about all gas leaks. Used it to verify no leaks in my new natural gas pipe, find tire leaks, etc.
When I first got the truck, there was a lot of black smoke coming out the tail pipe, more or less all of the time.
I changed the fuel filter and most of it stopped (I don't think it had ever been changed), but perhaps that is coincidental.
Now I get quite a bit of black smoke when I step on it.
I also put in a fuel pressure gague and the fuel pressure is running about 12-13 at idol and can drop well below 5 when I put the hammer down.
Any thoughts or suggestions would be great!
