Boost Whining - Don't Think It's A Boost Leak
- Replies 15
- Views 3.7k
Mopar1973Man 5 posts
NormaNator08 5 posts
Dieselfuture 2 posts
trreed 2 posts
Popular Days
Not good using the compressor wheel as a blender. The compressor blades may be out of balance and/or slightly bent. In the picture the blade at the 4 o'clock position doesn't lock quite right o
Background: Serviced my truck the other day and did oil change, oil filter, took off the BHAF and hit with air compressor. Went for a drive and noticed a whining sound once the boost started to build (never heard this before). Went back to the house immediately and pulled the BHAF/intake elbow and found rubber behind turbo silencer ring (see picture). I am not 100% sure where it came from. My helpful two year old could have put something in there while it was sitting on the ground, or it could have been a rubber tip that came off the air compressor attachment. Just not sure.
Anyway, I ended up taking off all boots before and after intercooler to blow out/check the lines as well as pulled the intercooler to hit with compressed air and try to blow out any debris (only got a small piece of rubber out). Replaced everything, and whining is still present.
So, I am still trying to figure out whats causing this sound... can't stand it!!
The sound happened right after the service, so that leads me to believe its not a boost leak on a boot.
Any help would be greatly appreciated. I am open to try anything.
Photo of rubber attached. Youtube link to see video and hear boost below.
https://youtu.be/FvXuhI38BME
Thanks in advance!
Video_Feb_04,_11_19_00_AM.mov
