Code problems p0238 p0112 p0521
I have 2001 dodge 2500 cummins and I keep getting this pain in the butt p0238 code. What could be the causes of this.
For the other codes I've already replaced the sensors but yet they are still illuminated I'm new to the diesel life so shine some light on this problem thanks!
  • Replies 9
  • Views 2.3k
  • Marcus2000monster
    Marcus2000monster
    Welcome to the forum! I would start by doing the testing in these here articles. I'm not sure if you have read these yet or not... I will say this. It don't always work to just by new parts without fu
Welcome to the forum! I would start by doing the testing in these here articles. I'm not sure if you have read these yet or not... I will say this. It don't always work to just by new parts without fully testing first. I personally have learned that the hard way. Lol. I would also clean all your grounds and just keep an eye out for shorts in the wiring.
And if you don't mind please fill out your signature with details and mods of your truck over in the account settings area. Thanks!
So I'm messing with the map sensor and it's read 3.42 and jumping 4.74 consistent with the truck no running is this normal or is it suppose to stay at a set voltage
I don't know a whole lot about it but go thru the testing section and I think it will tell you what your asking. Hopefully someone else will chime in and help you out. Sorry I don't know more than I do Haha.
It will vary voltage in relation to manifold pressure.   Seems a bit odd that it reads 3.4v on low end.   A couple other guys will chime in with decent ranges for the voltage versus manifold pressure.
HTH
Hag
HTH
Hag
Thanks Hag!
That's WAY too much of a jump.  It should stay very stable engine off.  Does the 5V source wire have steady and good 5v?
Does the ground have steady 0.00 resistence to ground?
If both are yes then get a Cummins Map sensor.
I believe all 3 of those sensors are on the same 5v buss so you might have an issue in the ecm, or the wiring leading to the sensors.
And for iat I was getting 4.96v also now have a p0236 code.
The map had a good reading of 5
Check oil pressure sensor too for 5 volts, there were cases where oil sender wood internally leak and short out. When I learned that I just changed my oil sensor to be safe. Not saying you need to start changing sensors for no reason.
Well fellas I reset everything bought a cummins map sensor so far everything is looking good except I'm still getting p0521 and p0112
