V2 2.7 long idle
V2 2.7 long idle
View File
This flash is a one off flash that contains all the stable functions of the normal 2.7 V2 flash, but it has a built in long idle function for keeping the truck running on key off, IF and ONLY IF, EGT turbo timer is set to 374*f.  The truck will idle until coolant temps come up to whatever your warmup temp is set to, regardless of what EGT's fall to .
This gives you the ablity to start the truck, key off, lock the doors, and let the truck idle, for warmup, while your keys are in your pocket.
Typical if tps > 0 will kill the truck as well.
It is somewhat tested, but there may be unknown bugs.
  • Replies 22
  • Views 13.1k
  • nope,  I dont trust the general public to use this without a run down of what happens if you set egt turbo timer to 374*.     I kinda wanted this for myself, so I coded it then thought maybe
  • Some of us have had this capability for years Nick!
  • yes, but then you have to set it to 100*F.  I wanted to have EGT's be reasonable that the turbo timer worked when the truck was warm, but have it long idle if ECT was below the warmup setting.  I dont
I've hit the wrong nail plenty of times growing up on a farm...  Never thought about that phrase before though.  Most phrases after the swing contained 4 letter words.
Ugghhh, things like this make me realize I need to fast track a quad purchase even if I’m still all stock otherwise.
