Hey guys so i think i narrowed down the surging to one thing. P0500 obd code. I replaced the speed sensor in the tranny and it worked for a little while. Im still dealing with this issue. I ohmed the two wires to the pcm connector and they are good. My boss suggested a short to ground. I know its a wire issue now because i went over a bump and the abs/brake light came on again. What are some grounds and other things i can check? Battery terminals are new and clean. Anybody else have a problem like this? I have a p1693 code that follows after the p0500 is thrown too. Assuming that its because of the vehicle speed sensor circuit 1.
- Replies 6
- Views 7.5k
DTech22 2 posts
Mopar1973Man 1 post
dripley 1 post
GSP7 1 post
