Well I'm getting tired of my fuel gauge reading 3/4 tank with 300 miles on the clock...  Its been acting up for some time but getting worse as half tank is about as far as it will ever get to.  If this was a true representation of some amazing fuel mileage then I'd feel a bit different.....but sadly its not.
So I guess I'll drop the tank, or lift the bed, and see whats up...  I'm thinking the fuel sending unit on the module is toast.  I see Geno's sells them but I was wondering if anyone has any suggestions on who else does?
Just for reference, the module is stock because I've never needed to modify the fuel module system.  Most video's and information about the fuel modules are because someone was trying to install a Drawstraw, remove the intank pump, or perform some other possible concocted modification.  I just want to fix the fuel level since driving by the odometer is kind of a pain. :thumbup2:
EDIT: Not sure what I was thinking but lifting the bed isnt an option because of the 5th wheel hitch.  Guess I'll be dropping the tank...
Edited by KATOOM
  • Replies 6
  • Views 1.2k
  • If you just need the gauge part I might have one.  Got it from geno's couple years ago.  Never put it in because once inside module found out what as a mess.  Ended up getting entire new module with g
    Exactly what I did.
Vulcan sells a fuel module for the 2nd gens. It looks very much like the I got when Dodge blessed with my in tank pump except without the pump.
Wow...modules arent cheap.  At 1/3 the cost, I'll certainly try replacing the sender itself first.  Thanks dripley
If you just need the gauge part I might have one.  Got it from geno's couple years ago.  Never put it in because once inside module found out what as a mess.  Ended up getting entire new module with gauge.  If interested let me know as I have to make sure I still have it (ie find it??)  on west coast.
