Injector ash
So i pulled my injectors when i installed valve springs and mantons...well they were dirty as heck and full of ash.could barely see the holes,truck has had optilube every tank since injectors went in (2 yrs ago).is this normal??thanks
  • Replies 25
  • Views 7.1k
  • So this is what ive been running and after the look of moparman injector with 2 stroke i will be discontinuing use What I don't get is it says keeps injectors clean but I have been running this
  • I have stayed around the 1 oz gallon but not to the point of being exact by any means. I also see several places where i buy fuel mixed with bio diesel. I usually dont run any 2 stroke if i am running
  • probably ought to change over to low ash 2 stroke oil.
You can see the small chunks on the cloth...
Really not that bad. Actually, it's pretty good.
Now, this is injector ash.
Ok thank you...i will stop worrying... also the ones in the pictures you posted what causes that? Those look horrible
Ash. Metal in oils. Typically this is caused by ATF, Waste Engine Oil, etc. ATF contains things like anti-scorching compounds, friction modifiers and other soft metals like zinc added. Waste engine oil is the same way with zinc and other soft metals added and compounds to extend the life of engine oil. Now when you burn this the metals come out as ah as seem above. This why the 2 cycle oil theory was created to resolve these issues of ash. Now back in the 1970 ATF didn't have all these compounds and same with engine oil.
