- Replies 18
- Views 4k
Tyler Stout 5 posts
dripley 3 posts
Me78569 3 posts
Silverdodge 3 posts
Popular Days
I don't know about the quad tuning, but those tires and wheels sure are not helping. The weight and circumfrance will knock the mileage of quick especially on the 3:55 gears. If you had to lift the tr
Set your minimum pump tap fueling percentage to 0 and ur tps pump minimum to 40 ur bringing 25 percent of wire tap in at all times that's why she's drinking if I'm correct u need to rely on canbuss fu
I am leveled on 35s and can pull 16 to 20 with 7x10s and a sxe 62 68 14 with my tune I run about 850 to 1100 depending on the hill and rpm anything under 1500 rpm and I fall under the turbo but o
Just want to say thanks in advance. This is my first post on here but have been a member for a while now. But I’m looking for some help and I have not tried searching all that much as my setup is different than most. For some reason I can’t get any better than 13mpg out of my truck. Truck info is in my sig. I am running 35x12.50 Toyo Mts on 20x10 Fuels. It has 3.55 gearing too. I am running the dd tune that’s for trucks with 50-150hp injectors but I have changed a couple things on it. Idk if it’s just the way things are setup but I hardly have any turbo lag and my truck runs good and hard but like I said I can’t for the life of me squeeze out any more than 13mpg. The truck is pretty hazy too under light acceleration. Any help is appreciated. Tune is uploaded in the pics. Thanks
Edited by Tyler Stout
Changed some information
