checking for boost leak
- Replies 10
- Views 3.3k
Dieselfuture 4 posts
jlbayes 3 posts
trreed 2 posts
Mopar1973Man 1 post
@Dieselfuture, there is a tolerance range that Cummins specifies. .006-.015 on the intake, and i forget the range on the exhaust rockers. But .008 & .018 are within spec. That's what I run too.
When you start putting 60psi+ through stuff you'll understand the need for it.
OK guys when checking for boost leak do i plug off air horn when i pump it up to 20lbs it don't hold very long i bought tester looked at tube didn't find no good info but installed boost gauge it makes 20 when mashing skinny pedal down 4lb at 50 and holds it 6-8 at 70 holds it could i still have leak its a automatic thanks
