Tappet cover for 24v
I am fixing to replace my tappet cover gasket as it has decided it wants to leak quite a bit. Before it was a 1 maybe 2 drops on the ground total and now the side of my block is black and it leaves a bigger puddle of oil than what i would like too on the ground. Not very much still and oil level is checked to make sure its safe! But, I want to know if I can purchase this 12v tappet cover off ebay and bolt it right up with a new gasket? Or will it not work? I Want the extra vent and c ant jar loose of $300 for a billet one.
  • Replies 22
  • Views 8k
  • Waydin_Stewart
    Waydin_Stewart
    My version of cheap is $5 not 25 haha. but okay ill get a new gasket at the parts store.
  • If the gasket was not painted and black in color, it's a good possibility it was the OEM gasket.  Would also recommend a replacement.
Yes, the 12V tappet cover will bolt right up.  Works great.
specific part number I need? this ebay seller has 3 that all seem too have different number. and do i then need a gasket for a specific year 12v or will the 24v gasket work aswell
Different part #'s could be due to different industrial applications. As long as the breather is a square in the back-most part of the cover, it should work fine. A 24v tappet gasket will work.
3911821 is stamped on this 12v tappet cover. It looks to be painted black and has red fade on the inside of the cover. I hope the black isnt covering up bad rust on 1 side of the cover.
Link?  I'm betting it was from an industrial application and then painted black to match some guy's truck.
I would do the first link since they're all the same price and it looks the best.  IIRC it's 3/4" hose for the breather
Would still do the first link from the group you posted.
Alright thank you! I will  have a buddy order it as he doesnt mind ordering that stuff on ebay haha and he has an account and i do not.
I got the tappet cover in yesterday. It appears to have been off an industrial motor as it has remnants of red on inside of cover. the seller shipped it with a gasket and painted it black. Should i use the gasket he supplied or order another one? The gasket was already on the tappet cover so i dont know what brand. seems to be some kind of rubber.
As cheap as they are I think I would put a new one on for peace of mind.
A Fel pro is only $15 and a Mahle is less than $10 on rock auto. Of course if you need it today that would rule them. But if you have time there are probably more to be found on the interweb.
I just always get gaskets and really all my parts from oreileys cause of the lifetime warranty.
he used the stock bolts and this gasket as "masking" cause i can pull the gasket off and there is a silver ring where the gasket set. and the sides of the gasket are a dull black and the top is shiny black.
4 hours ago, IBMobile said:
New gasket equals cheap oil leak insurance.
6 hours ago, Dieselfuture said:
Yeah, get a new gasket regardless
Okay thank you! I will go get one at the parts store today.
