Suspension setup help
- Replies 57
- Views 11.1k
Waydin_Stewart 17 posts
AH64ID 11 posts
JD435 7 posts
dripley 6 posts
Update, Received the Moog CC1712 springs from Rock Auto on Saturday. Was shipped from Hampstead, NY by FedEx for $23. The springs where made in good old USA! The box weighted 54 lbs. Each spring
The adjustable mounting bolts on the control arms are for alignment and will not have any effect on the ride height. My guess is that after 20 year the heavier drivers side has sagged the
Would you have to replace four? I believe @AH64ID means front and rear to match up. I would defer to @AH64ID for the need on that. I measured mine and they are only 9" fender to
I noticed on my 1998.5 dodge that the passenger side is 1” higher than the drivers side? I have not to my knowledge adjusted anything on the truck that would make 1 side sit 1” higher? I measured with a tape measure and it’s 11.25 on passenger side to top of tire and 10.5 on driver side to top of tire. Isn’t there bolts with oblong nuts on control arms? Orrr how would I fix this?
