- Replies 37
- Views 6.3k
portlandareae28 11 posts
Mopar1973Man 9 posts
Marcus2000monster 8 posts
trreed 3 posts
DDRP pumps use M12 fittings (stock banjo bolts). Fass 150 uses -08 JIC fittings and 1/2” NPT fittings.
Enuf said... I kept my stock filter housing and still use it. You'll need to get a big line kit between the stock filter and injection pump.
Just bare in mind a big line kit by itself is not going to make much difference if you are still pulling fuel thru the stock lines.
If everything surrounding the DDRP is stock, is it limiting the DDRP/fuel pressure? Would it be beneficial to increase fuel line size? And what other benefit that would also be beneficial when I upgrade from the DDRP to either a more powerful mechanical or electric pump should I do?
