- Replies 12
- Views 5.5k
Mopar1973Man 5 posts
domgbrl 3 posts
dripley 2 posts
Marcus2000monster 1 post
Popular Days
Test for excessive AC noise issues. Then if you do find an issue, you'll need to replace your alternator then also consider doing this mod too.
More than likely the crank sensor like @Mopar1973Man says. Get the codes read to be sure. Hate to see you throw a part it.
Crusing at 1800 rpm, the tach needle is bouncing/ jumping up to 2000 rpm. And when this happens the truck seems to be bucking and jerking slightly. Any ideas??
