Power Steering Pump
Hopefully replacing my power steering pump tomorrow. There is a threaded pressure line at the bottom of the pump and then I think 2 return lines to the pump from the booster and gearbox. If they are both return lines, does it matter which stub the hoses are attached to on the pump? I was reading IBMobiles filter article and I may have my return lines crossed, but in theory it shouldn't matter. I also have a filter on the line coming from the booster to the pump where IBMobile has it on the line from the gearbox?
  • Replies 25
  • Views 5.6k
  • Well I hate to say this but I have never completely changed or flushed my PS fluid. I have on several occasions taken the "turkey baster" thing and sucked what fluid I could get out of it and replaced
  • IBMobile
    IBMobile
    It shouldn't mater.  They are both return lines to the reservoir part of the pump.
  • I have 442k on my oe pump and keep waiting for it to explode. It is a touch weak and shows that at idle every so often. Probably ought to just replace. I believe I got my moneys worth out of it.
Let's just say Dripley's abusing his truck a bit. Maybe that turkey baster is just enough to keep you from trouble. I still suggest purging the system and refreshing the system completely forcing all old fluid out and refill with fresh fluid.
Not the same make of vehicle but I got around 597,000 and 40 years on the original power steering pump in my 78 F150. The fluid gets slowly replaced since the swivel joint on the pressure side seeps and has for the 21 years I've owned it and no telling how long when my grandpa owned it. It has that whiney and growling pump that Ford was famous for in the 70's and 80's. Still has the original untouched steering box too.
He speaks a lot of truth on this. I also have a weepy head gasket for believing the 100k mile change of coolant like the owners manual suggests. Go figure!!!!!
1 hour ago, dripley said:
I have on several occasions taken the "turkey baster" thing and sucked what fluid I could get out of it and replaced it.
Oh man, here we go.... dont let @IBMobile see this :stirthepot: sorry I couldn't resist. :cheers:
I had mine whipping oil at 120k that's when I bought my truck, drove with rtv in front bolt hole for maybe 6 years or more and had 154k when I finally changed it because the leaking got bad. I did change all fluids when I first got it though. When I took head gasket off it was missing chunks in more than one place, I'm surprised I didn't have more problems.
