I keep getting P0237
- Replies 9
- Views 6.4k
dripley 4 posts
Mopar1973Man 2 posts
Ed ke6bnl 2 posts
Me78569 1 post
Popular Days
Here are a couple pics of the ground wire splices I am speaking. This first one is of the splice of the ground wires from sensors. This is similar to the ground splices described in @W-T's ground wire
in theory the edge should prevent that code from happening unless it is bad or you have a short between the edge and ecm.
The ground wire splice I spoke of are buried in the engine wiring harness. It is not like a ground to the body or such.
I keep getting P0237 when I rev the engine quickly, was lucky it did not do it for the Calif. smog check because it passed without throwing the code for him. I read that it is turbo boost sensor A circuit low. would appreciate some info on this. why and what sensor is reading this. truck seems to run fine and boost will go from 0 to 28 psi. thanks.
