I'll preface my post by committing $200 to anyone whose recommendation solves my issue.  This is not my truck in the YouTube video but it accurately depicts what I'm experiencing.
https://www.youtube.com/watch?v=xudW4yafWTc
Here's some brief maintenance history on my truck:
1. Newly rebuilt tranny
2. Replaced 3 separate TPPS (WELLS, Timbos and Stock) to try solve issue
3. Installed RAPTOR 100GPH lift pump (16PSI at idle, 15PSI highway)
4. Newly installe remanned VP44 pump
5.  All battery cables replaced with 2/0
7.  Thoroughly cleaned engine block grounds on both sides of the engine
8. ATS signal conditioner install at PCM
9.  No code errors
S.O.S.
I desperate guys!! Please help!!
  • Replies 60
  • Views 10.6k
  • Dieselfuture
    Dieselfuture
    I had buking/surging a while back. What solved mine was rebuilt alternator(brushes armature etc) putting more ground wires for bonding (before I did ground mod mentioned above) and finally new injecto
  • Dieselfuture
    Dieselfuture
    Hopefully that fixes it, and if not we will all help with what we can, but I'm pretty sure whatever money you want to offer everyone will tell you just donate to this place.
  • how about conditions?  Is it regardless of throttle input?  does more or less input change the result?   Please give us as much info as possible so we understand what systems are involved.
And a bad alternator. Ditch the ATS noise filter return the electrical back to stock. Most likely replace the alternator but have it tested for AC ripple. Then you'll want to do this ground mod.
8 minutes ago, Mopar1973Man said:
And a bad alternator. Ditch the ATS noise filter return the electrical back to stock. Most likely replace the alternator but have it teated for AC ripple. Then you'll want to do this ground mod.
I'll try this exercise and report my results.  Not to mention the alternator is new.  By the way, just to show how desperate I am, I ordered the diode bridge (Order #1698) from you to have my spare alternator rebuilt to try to out.
Edited by Toughspot
Did you do the ground mod?
What typically it is the ac noise muddys the tach signal and the ECM start the bucking. Another way of testing is disconnect the alternator field lead go for drive. If it goes away the problem is for sure AC noise related. Noise filter is a huge clue in this and should be removed.
I disconnected the alternator per instructions in one of your post by un-clipping the wire and removing the 140A fuse.  I went for a drive and the problem still remain.  So I assumed the problem might not be alternator related.
Hmmm...
Could you list out all your mods you have on the truck in your signature? I'm looking for more clues on what it could be. It's still electrical natured.
Hmmm...
Okay will do... By the way these are my VAC readings I got from the alternator...  0.012VAC is across the battery and 0.033VAC is from the output cable of alternator to negative post of battery.
That why I'm asking for signature information so I can see if there is something else in the system muddy the signal. Do you have any tuners programmers anything like that? turbo? Injectors? Any engine modifications?
5 minutes ago, Mopar1973Man said:
Hmmm...
Mods on truck:
1. BANK Cold air intake
2. BANK intake elbow
3. RAPTOR lift pump 100GPH
4. CAT 2 micron high efficiency filter
5. Just added Edge-EZ
6. ATS signal conditioner
Just added tuner, but the problem existed before the addition.  Thought it might helped
Aurora 3000 Turbo charger
No other engine mods... stock injectors
what speed and conditions does it happen at?
light throttle  / heavy throttle?
1st gear or all gears?
By the way, I had this problem when the truck was BONE-STOCK...
I was hoping minor mods could help
Did you try test drive with the Edge EZ removed?
Do you have air bubbles coming through the fuel system? Raptor could be drawing air into the lines and since there is no air separator then it would start bucking. Under load the fuel flow is higher so ithe air bubbles will be more plentiful.
Still you will wnat to di the ground mod above. @dripley reported a 50% reduction to the noise levels. dropping him to the 0.01x realm.
This morning alone I was simply taking off. So my speed was about 10-15mph
I will do the ground mod this afternoon after work and let you guys know how it turned out
Mine went from .035 to .010. This was measured across the batteries and at the alternator output.
yes sir, regardless of conditions.  By the way I'm in the Bahamas so cold weather not a factor.  I removed the connectors from the PCM and sprayed them with electrical cleaner just in case salt might be an issue
I will definitely do this ground mod this afternoon
2 minutes ago, Me78569 said:
Does it do it in first gear?
Whenever I give throttle... But idling out to the highway through my community it doesn't happen.  But yes... It happens it 1st gear.... Or as long as the throttle pedal is depressed
I've already replaced the TPS 3 times
If it happens in first we can rule out TC lockup issues.
does your truck have smoke, white or blakc when this happens?
I haven't noticed but I will be sure to observe...
Since it happen in first gear and chances not a TC lock up issue, can it still be attributed to bad grounding?
How are you scanning for codes?
Do you have anyway to track sensor data to see the values they are reporting?
