Quadzilla & EGTs
Got the Quadzilla in and working. Just playing with the V2 tune and I noticed improvement in my EGTs as the power level went up. I was told that someone on this forum had a "Mileage tune" that also lowered EGTs. Anyone willing to share that?
  • Replies 8
  • Views 2.4k
I'm working at an MPG tune because of my long travels.
WARNING! - I'm running some pretty steep timing. - TRY AT YOUR OWN RISK
iQuad-Economy-2018-06-13-01.12.061551729168.json
My overall EGT at 55 MPH can be as low as 450*F on flat ground. Even at 65 MPH I float about 550*F EGT
Worth noting that the tune is not based on stock injectors.  So the Eco tune on a stock injector truck will be dog slow
+50 injectors. What app do we use to import a tune?
Your device. So like if I was to import that back I would grab my cellphone surf the page and download the file. Now fire up the iQuad app on my cellphone. Switch back to your download and now open it. It will automagically import to the iQuad App. Now shut down the app. Restart and the tune will be in the iQuad. If you don't cycle the app it will act like its missing. But if you attempt to import again it will say it already there.
Thanks. I will try it when I get back to the truck
GOT IT! Would you recommend any timing adjustments for safety or just give it a try?
I believe in your canbus 14psi should be 131 judging by increases you were using and the rest would go up by 1 also, but maybe not. Just seen it and thought I'd mention it. Probably not noticeable ether way, it just stood out.
What have you been averaging on this tune so far.
