- Replies 6
- Views 4.2k
Mopar1973Man 1 post
JAG1 1 post
beren 1 post
015point9 1 post
Popular Days
"Marine" grease just a little bit more water and corrosion stuff if I recall right. It's the "base" material you might have problems with if mixed. If both lithium based no worries. National grease
Mixing greases of the same or compatible base is no problem. If the grease base is not compatible then the lubricant oil can sperate or give no protection at all. When I can't determine what the gr
Mixing Lithium and Moly are the typical no no's everyone worries about.
I put marine grease in my grease gun to grease a clients water wheel bearings. Is it contaminated now so that I need to clean out my grease gun before using my regular BJ and tie rod grease?
Any answers related to chicken grease will be disregarded .
Thanks in advance
