2010 6.7 Running Hot
- Replies 15
- Views 18.1k
Mopar1973Man 5 posts
AH64ID 3 posts
MtnManMegaCab 3 posts
trreed 2 posts
Popular Days
How is the air flow over the radiator cooling fins, rat nest or other obstructions between it and the intercooler? How is the coolant flow through the radiator cooling tubes. No blockage with ca
Thanks guys, lots of good information. I replaced the Fan Clutch and flushed the coolant and that seems to have fixed it. The coolant was low and had a pretty good air pocket burp when I took the radi
Hey guys, so a few months ago I was towing the bass boat to the lake and the temp started shooting up on my Cummins (230-240degrees) and then lowering back down. So I immediately replaced the thermostat and no issues for a little while. This past weekend I was on my way back from a road trip with the family and it started doing it again about 10 miles from the house so I just nursed it home and let it cool off. I did some research and thought it might be the electric Fan Clutch, so I replaced that little PITA and took it for a test drive and low and behold it started doing the exact same thing. This is a 2010 Mega Cab Laramie 2500 6.7, deleted and tuned using a H&S mini maxx, and I typically run it on the street tune and not performance, but am not beating on it hard at all. Any help would be appreciated as to what is causing it to run hot.
Thanks
