- Replies 28
- Views 15.6k
Mopar1973Man 9 posts
tylertrebilcock 6 posts
dripley 3 posts
Ed ke6bnl 2 posts
Basically what it comes down to is reducing rolling resistance, rotational loss, and drag. More you lean towards the 3.73 ratio the lower the drag is on the vehicle. Like my design in tire is to put m
Make sure it's ashless, most run supertec https://www.walmart.com/ip/Super-Tech-TC-W3-Outboard-2-Cycle-Oil-1-Gallon/16795065
I went to 35 in tires and the mileage dropped, I bought a crashed 99 Ram with 4:10 gears and 80k motor and DTT transmission and exhaust brake Cheap used the 4:10 gears in my 98.5 ram and it is a go
Can anyone offer a suggestion as to why my fuel mileage is so poor, I have played with several different tunes on my quadzilla and still can’t get over 14 on the highway. I’m running 35 in tires. I’ve heard it could be injection pump but it was replaced not to long ago and it’s been running great so it’s hard to believe that’s the problem. I’m also on stock injectors
