Fuel gauge fluctuations
- Replies 23
- Views 5.4k
dripley 6 posts
Mopar1973Man 4 posts
Towrigdually 4 posts
JAG1 2 posts
LOL. I got one. I pulled a guy out of the backcountry because he thought he had enough fuel (3/8 of a tank) and forgot about the steep grade. As he ran up a steep grade in the backcountry
When it comes to the fuel you just have get used to what it reads. I know when I hit a half tank on the gauge it is really 2/3 rds. No big deal. When the light comes on I have about 3.5 gallons left.
I like that one. Most of my driving is on the interstate or main secondary roads. I have pulled some grades on that last 1/8 tank that made me wonder if that would happen. So far so good. I have run m
so I usually never let my fuel gauge get below 1/4 tank and during my last drive I did just ever so slightly.
When I took a sharp turn into the gas station my fuel gauge dropped right to 0 and stayed.
I immediately shut the truck off and then bumped the starter to listen for the fass to run, which it did. So I let it run but it came up normally but the needle then vibrates quickly as it climbs to 17-18 psi. If I let it sit for a few seconds it settles out no problem.
Now everytime i get slightly above a 1/4 tank it starts to fluctuate between 18 down to 7-8 whenever I stop or make a turn.
Side note, this is an autometer 0-15psi gauge and I've been overpressuring it for over 2 years. Could the gauge have went bad finally? Or maybe a different issue? The truck has no power loss and starts right up no matter how long it been sitting wheather it be over night or just enough to fill up. The fass 95 pump has been on for about a year now.
Has anyone ever had a similar issue?
Edited by Towrigdually
