Cursed DEAD PEDAL!!!
- Replies 13
- Views 3.5k
Mopar1973Man 4 posts
UnrulyDually 4 posts
dripley 3 posts
SilverMoose 1 post
Popular Days
What kind of fuel pressur are seeing? Are you still running on the stock fuel lines to the VP? I don't think that FRRP has much of a chance keeping up with the stacked tuners.
Any codes, have you changed apps sensor yet to Timbo, check vac at alternator, ground mods
The guys here are on the right track. Fuel pressure is the key to keeping the VP44 cooled and happy so if your fuel pressure is 14-20 PSI you should be fine but if you're below this then you running t
Im having issues with dead pedal. Dont know where to start?!? Its been getter worse. Was happening about once or so every few months....would forget about it, then it would happen again. An today it happened 4-5xs home from work(about 35kms). If i push in clutch an pump pedal a few times itl will come back....then randomly cut out again while just cruising( barely on the pedal). Wondering if this HOT summer weather has somthing to do with it?? Any direction would help thnx!
