I am on vacation and broke down need some help
- Replies 52
- Views 8.1k
AH64ID 11 posts
hawkeye213 8 posts
LiveOak 7 posts
ISX 5 posts
2002 dodge ho 6 speed stock I am on my way to montana from amarillo,texas and I am outside albuquerque. I set the cruise and am going about 70 mph down the highway. I start to notice the the truck starts to feel like it is surging. It is pretty hilly up and down and i think it is just the cruise adjusting and then all of the sudden the tranny just feels like the clutch just let go or the tranny locked up. It just starts to decelerate rapidly and just feels like the it is lurching like it does when your in 1st gear when you pull away. I push the clutch in and it just keeps jumping around. I get it pulled over on the side of the road. I get out and notice some fluid coming off the tranny. It is not thick tranny fluid but thin almost like the brake fluid for the hydraulics. It seems to be coming from on top of the tranny. I can see where the hydraulic slave goes for the clutch and no fluid there. The hole unit all the way up to the reservoir is dry and the reservoir is still full. I cannot shift the transmission at all. It feels like it is in nuetral but cannot shift anyway at all. I pushed the clutch in and started the truck and slowly let the clutch out and it started to go back like it is in reverse and it just sounds like every thing is teinging around in the tranny. It sounds so bad I just know the tranny is just trashed. The clutch seems to be working. Any thoughts. Thanks Rob
